Check Engine Light - Code 16 - injectors - not main relay
Old Oct 3, 2008 | 12:28 PM
slow_dx's Avatar
Default Check Engine Light - Code 16 - injectors - not main relay
Hi Everyone,
I have a 2000 civic with a b20z swapped into it, running a chipped obd1 ecu. It's been throwing cel code 16 - fuel injectors. I've replaced the main relay, but this was not causing the problem. I've also run the standard injector tests w/ noid lights, measuring resistance, and listening with a stethoscope - the injectors are fine.
Can anyone tell me where the wire harness is routed in the car? Any points I should be checking?
As an aside, I went to pop my hood to inspect the wiring, only to find that my hood release no longer works. Talk about a bad day.
sakasaku
Aug 20, 2009 01:27 PM
H22Ej1
Jan 23, 2009 10:35 AM
MUGEN_EG95
Sep 3, 2008 08:57 PM
delux247
Jan 28, 2004 11:48 AM
Turbohatch
Sep 4, 2001 03:38 PM
