HELP!! chopped obd1 wire harness
(I have a 92 civic dx) iv figured out just from looking at the wire harness where some of the plugs will go for my jdm gsr swap, but i cant figure out what these chopped off parts of the harness is for.. please help!.. im planning on starting the swap on monday so i wanted to figure out the wiring before i tore the motor out of my daily driver. thanks
Modified by importracer0008 at 12:24 PM 9/28/2008
Re: HELP!! chopped obd1 wire harness (philafelman)
would you like to elaborate on that a little? i know you need the wire harness that comes with the specific motor for it to work. so what do you mean?
Re: HELP!! chopped obd1 wire harness (importracer0008)
you should be able to use youre stock harness...obd1 plugs should be the same on both motors, you will just need to run vtec wires to the ecu.
civichbsmn
05-05-2007 08:25 PM
Supa_Slow_Civic
10
07-21-2005 06:47 PM
