Wiring B series swap Ef sedan (noob question)s
I have a b18 ls motor i am planning on swapping into a ef sedan. I can get the motor with the ecu and harness (the tranny is a automatic) So that means as well is the ecu. I plan on finding a GSR transmission to bolt up to the ls motor. I plan on going turbo so i think i might need the manual ecu to chip.
1. Should i go ahead and take the harness, but grab a b series manual ecu and replace the original harness with the b-series one or is that even possible?
2. Should i just grab a b18 manual ecu and wire it up to the original harness in the civic despite i would have to wire up for two more injectors because it is dpmfi?
Just let me know of any suggestions and advice thx i appreciate it
Re: Wiring B series swap Ef sedan (2point2)
cool, so i just hack the b series ecu plugs and fit them to the original harness, and plug into my manual b-series ecu, does this sound right?
Re: Wiring B series swap Ef sedan (threehonda)
do you have mpfi or dpfi?
if you have mpfi just put your stock on the motor
you dont have to cut or rewire anything
now if you have dpfi you will need a si,ex or hf motor harness and run some wire to the ecu
HONDA CRX/EF CIVIC FAQ'S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by threehonda »</TD></TR><TR><TD CLASS="quote">cool, so i just hack the b series ecu plugs and fit them to the original harness, and plug into my manual b-series ecu, does this sound right?</TD></TR></TABLE>
What you want is an OBD0 to OBD1 jumper harness. You will have to do a DX to SI conversion as well.
ah well, i just found out the guy i was buying the motor from sold his head, im just going to fix the civic and sell it. This way i build the lsvtec and find something later on with a bad motor, like a 92-95 civic. My plan was just to swap in as is and then head swap when i could afford it. But now i have a short block for 50 bucks. I will just build it.
Thanks for the info and help though, i am gathering as much as i can
Zack Tieleman
06-20-2016 06:49 AM
[713]
04-09-2015 09:25 PM
