slow car
Old Oct 20, 2008 | 07:37 PM
teamvirus's Avatar
My car breaks a lot!
Default slow car
ok so ive done a few swaps in my civic and everytime i do it the motor is slow as **** and i have no idea why this could be.
swaps ive done:
b16 turbo
ls-vtec turbo
b20-vtec
mods: stage 1 clutch, fidanza flywheel, molbro fuel pump, skunk 2 mani, headers...
you know the basic setup that most everyone has, now im not saying with this setup i should be crazy fast, ive only really wanted to be quick, low 14's with a b20 vtec shouldnt be to much to ask for. and its not just "the driver" the car is just lame or something...and i know i should tune my car but i dont have the money at the moment so that wont be for a while
im running a stock b16 ecu most of the time
the funny thing is the car runs good, no codes nothing like that
but its SLOWWWWWWWWWW!!!
wtf should i do other then sell my car and go buy a new car
example of how slow i am
racing my friends stock b16 swapped eg and he pulled on the freeway vs my b20 vtec em1, b20vtec should never get pulled on by a b16
its almost time for me to give up
Old Oct 20, 2008 | 07:46 PM
Jaker's Avatar
Default Re: slow car (teamvirus)
Save your money, and when you have enough, spend it on tuning. You're wasting your time and money with this if you're not willing to get it tuned. The B20Vtec will run lean with a B16 ECU. That will rob you of power, and eventually lead to a blown motor. You'll need some sort of aftermarket engine management (chipped OBD1 ECU with adapter harness, or plug and play system like AEM/Hondata converted ECU with OBD2 plugs) and some bigger injectors to tune a B20Vtec properly.
Old Oct 21, 2008 | 10:21 AM
95vxtealhatch's Avatar
Get it tuned.
Old Oct 21, 2008 | 02:42 PM
teamvirus's Avatar
Default Re: (95vxtealhatch)
dont you think a untuned b20vtec should still be faster then a b16?
Old Oct 22, 2008 | 03:27 AM
teamvirus's Avatar
Default Re: (teamvirus)
Old Oct 22, 2008 | 06:14 AM
Specail Ed's Avatar
It's because you have a Honda!!! Hardy har har!!!
Old Oct 22, 2008 | 07:00 AM
LA_HONDAS's Avatar
Default Re: (Specail Ed)
get your ecu chipped click here
Old Oct 22, 2008 | 08:40 AM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">dont you think a untuned b20vtec should still be faster then a b16? </TD></TR></TABLE>
Its possible, but not probable.
Old Nov 5, 2008 | 04:51 AM
teamvirus's Avatar
Default Re: (Jaker)
could it be that my compression is 9.15:1?
im using a stock usdm b20 block
if i had jdm b20 pistons my compression would be 10.03:1
Old Nov 5, 2008 | 05:31 AM
Jaker's Avatar
Why are you wasting your time and ours? It's plain and simply needing to be tuned. I have a straight B20B (not Vtec) in my 89 Civic, and it is pretty fast and fun to drive. A big part of why this is, is because it is "tuned". Spend some time and money getting it tuned, and if it's still "slow" come back and see us.
Modified by Jaker at 7:44 AM 11/5/2008
Old Nov 5, 2008 | 08:07 AM
98vtec's Avatar
moderator emeritus
Default Re: (Jaker)
b16 ecu on a much bigger motor....
Old Nov 5, 2008 | 01:38 PM
DSRxCandyh2bEG's Avatar
mods: stage 1 clutch, fidanza flywheel, morlbro fuel pump , skunk 2 mani, headers...
Its the fuel pump, it cant breathe right cause of all the cigarettes its smoking... =X
lol, jk.... get it tuned. I cant imagine running a swap without dialing it in with a tune. What year b16 ecu?
Old Nov 5, 2008 | 02:01 PM
teamvirus's Avatar
Default Re: slow car (DSRxCandyh22EG)
99 si ecu
1EK1EG
Appearance Build Threads
Aug 19, 2010 05:33 PM
joshluis
97
Jul 8, 2008 09:48 AM
jdmh04
Oct 27, 2006 01:45 AM
EG 4619
22
May 3, 2005 07:29 AM
974drgs
Jan 23, 2005 06:22 PM
