name this sensor
Old Sep 3, 2008 | 04:15 PM
orioncivic's Avatar
Default name this sensor
what sensor is the green one? it has 2 wires on it and it is just above the oil pressure sending unit?
i was told it is the coolant temp. sensor? and also told(by another) it is the sending unit to control the rad. fan i have a sensor on the thermostat housing that isnt on the b16 block i was told to rewire it to this one but there is also a sensor that looks identical on the head under the vtec switch
Modified by orioncivic at 5:21 PM 9/3/2008
Old Sep 3, 2008 | 06:22 PM
Civic H22's Avatar
knock sensor
Old Sep 3, 2008 | 06:46 PM
kalm_traveler's Avatar
Default Re: (Civic H22)
all the ED-chassis Civics I've fixed up have that on their D15/D16's. I believe it's a water temp sensor for something.
Old Sep 3, 2008 | 07:44 PM
LA_HONDAS's Avatar
Default Re: name this sensor (orioncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orioncivic &raquo;</TD></TR><TR><TD CLASS="quote">what sensor is the green one? it has 2 wires on it and it is just above the oil pressure sending unit?
Modified by orioncivic at 5:21 PM 9/3/2008</TD></TR></TABLE>
tell them to do some more research
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic H22 &raquo;</TD></TR><TR><TD CLASS="quote">knock sensor</TD></TR></TABLE>
its to low for the knock sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kalm_traveler &raquo;</TD></TR><TR><TD CLASS="quote">all the ED-chassis Civics I've fixed up have that on their D15/D16's. I believe it's a water temp sensor for something.</TD></TR></TABLE>
almost got it
its a fan switch that come on all obd0 motors
one wire go's to a ground and the other go's to the relay ground
Old Sep 3, 2008 | 07:50 PM
LA_HONDAS's Avatar
yes you have rewire it
it just a off and on switch for the fan
sleepingciv
Nov 2, 2008 08:14 PM
DC_Legacy
Jun 3, 2008 06:13 AM
WalkerGSR1
Oct 29, 2006 02:46 PM
