Got some plugs left over on my H2b swap???
Does this go here on the water neck??
Where do these 2 plugs go not used??
What about these??
What about these??
Re: (ekb16)
that last plug is for the o2 sensor...you can see where it clips onto the bracket and will go the exhaust. also, the second picture (right plug) looks like it could be for the knock sensor. im not 100%, but if it only has one wire, its likely. the ground cable goes to that bolt you have loosened in the middle of the 3rd pic. and the connector by the thermostat looks like it may go up to a plug on right to the right of the vtec solenoid plug. hope that helps.
Modified by philafelman at 2:10 PM 9/26/2008
chads
06-04-2005 02:32 PM
