quick b16a2 into eg question
Old Oct 27, 2008 | 03:17 PM
mikegeezy's Avatar
Default quick b16a2 into eg question
ok my b16a2 has a sensor wich i am assuming is the crank position sensor it is located by the crank pulley under the timing cover my question is obd1 has the crank sensor in the distributor so if i use the b16a2 obd2 distributor with a distribotor jumper harness do i have to extend the sensor that is by the crank pully and splice into the harness i am confused some1 shed some light on this issue please thankx
Old Oct 27, 2008 | 03:25 PM
LA_HONDAS's Avatar
Default Re: quick b16a2 into eg question (mikegeezy)
you dont need it just take it off or let it stay on there
obd1 have it in the dizzy
Old Oct 27, 2008 | 03:32 PM
mikegeezy's Avatar
Default Re: quick b16a2 into eg question (LA_HONDAS)
i am not using obd1 dizzy i am keeping the obd2 dizzy and using a distributor jumper harness so then thinking about it i will have to run the wires and splice correct or just get an obd1 dizzy
Old Oct 27, 2008 | 03:36 PM
LA_HONDAS's Avatar
still dont need it
i have a obd2 dizzy in my crx and it runs fine
sikcrx80
May 1, 2023 05:16 PM
akinas-crx
Oct 28, 2011 06:00 PM
Archidictus
Nov 22, 2007 08:11 PM
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
civicEXtreme
Jun 14, 2006 03:17 PM
