Best swap for the money?
Okay heres my situation, ive got a 99 civic cx with a y7/y8 mini me done by myself. It is gettin to be in rough shape(burns oil , bad tranny,and i think the headgasket is leaking a little). Now i know that i want to upgrade. I will have around 1300.00 come febuary saved for this and i would appreciate some opions on what to do. I almost want to just do a complete rebuild but have longed for a dohc for a while. But what could i honestly get for only 1300.00 bucks? I will do the swap myself so labor fee would be at myown expense. Thanks
Re: Best swap for the money? (faxshatch)
For that money, you could go with the simple vanilla flavored B18B, and get a GSR or SI transmission. You can keep that for a bit until you may get tired of 130HP and have money by then to get a little turbo kit. You could also get a D15B VTEC, but that's SOHC and you said you wanted to go dual soon.
318 Curves, 11 miles
Re: Best swap for the money? (davefromPA)
LS or B20. I see B20 longblocks going for under $1000 pretty often, although you'll still have to source a transmission and some other stuff. Honestly, when I was looking for my swap though, I couldn't find anyone selling B18bs for any kind of reasonable price.
Really though, if you're willing to wait, keep looking, and save a little more, you can get someone's B16 or gsr swap reasonable from the marketplace. I was seriously considering doing a HMO B20 swap because I thought I couldn't afford a B18C until I found another h-t member selling a 99% complete, lower mileage B18C/b16 trans swap for $2000. I had to drive to Chicago to get it, but it still beat shipping costs quite a bit.
So, using ballpark figures: a B20a has an estimated 127HP at the crank, and costs about $1000 shipped. You'll still have to buy a B series transmission (say $400), and an intake manifold (about $200). Plus various odds and ends mounts, etc that you'll find needs replacing. Say, $1700, possibly more. That's $13.30 per 1 HP.
Using mine as an example: $2K for the complete swap - a USDM gsr rated at 170 crank HP. I had to buy replacement axles ($100), flywheel resurface ($40), and a clutch ($90), for a total of $2230. That comes out to 13.11 per 1 HP. About the same as a B20. Of course, you might find a B20 cheaper in the marketplace.
The moral of the story is that the best bang for the buck is to either look for a deal on someone else's swap, or go B20 IMO. I don't think that it's possible to do a DOHC swap for $1300, but if you were going to, it would be LS or B20, and I think the B20 has more NA fun factor because of the higher torque.
that's true, if you wait and keep saving your money, you'll come up on the perfect deal. i waited for my h22 swap and paid a grand total of 1800 after everything was said and done. It also helps if you have good hook up's at a shop as well.
Re: (rpared01)
Wow! You know i mite have to do that, i work for cianbro during the summer i mite be able to really save up some money towards this! But i gota make payments on student loans too hope its worth it in the long run lol Ill do sum research thanks again guys!
I traded my Z6 swap and $1100 for my H22 swap with new (previously owned but unused) axles and mounts.
Save your $$$, and wait for the right deal to come along. When someone drops it in your lap, be ready with the cash
Good luck with the build
theslugbug
06-15-2010 10:16 PM
