Help with clutch bleeding on evo h2b??
Old Oct 11, 2008 | 05:42 PM
turboedsupe's Avatar
Default Help with clutch bleeding on evo h2b??
I have tried the old fashion way with a friend in the car and have tried a vacuum pump. It is moving and there is feel in the pedal just is too soft. Its a CC stage 4 and the petal feels stock. Wont go into gear either. My slave worked just fine on my 1.5 but maybe it needs a new one??
Old Oct 13, 2008 | 03:17 PM
LA_HONDAS's Avatar
Default Re: Help with clutch bleeding on evo h2b?? (turboedsupe)
buy a qsd kit and everything will work like stock
QSD FTW
Old Oct 13, 2008 | 04:01 PM
Default Re: Help with clutch bleeding on evo h2b?? (LA_HONDAS)
Haha yeah but its already all installed. Anyways after bleeding it for 2 hours i held the clutch down and had a friend pry the fork back and extend the slave all the way to make sure the clutch would even disengage. For some reason after that it works fine. Does that sound like a lazy slave or what?
Old Oct 13, 2008 | 04:26 PM
LA_HONDAS's Avatar
maybe
if you change it get from honda its better then the $20 reman junk
Old Oct 13, 2008 | 08:32 PM
Yesterday when my friend adjusted the clutch he left no play in it. So today when i was driving and got on it the clutch would slip. So i went and tried adjusting the clutch and when adding play the MC sounded like it sucked air in and now the slave wont extend fully. Is the MC leaking? I thought i seen a little fluid on the firewall but not the inside, but the clutch worked fine before the swap any ideas
Old Oct 14, 2008 | 06:59 AM
LA_HONDAS's Avatar
is the floor wet under the dash by the mc if it is replace the mc
Old Oct 18, 2008 | 10:24 AM
Ok replaced slave and MC and still have the same problem. I bench bled the MC and have bled it with everything installed. The fluid does shoot out alot better with the new components but it still wont disengage. Any advice will be helpful i dont want to take my car to a shop over something so simple. Here is some pics of it closed and open
Old Oct 18, 2008 | 11:22 AM
LA_HONDAS's Avatar
get a qsd slave and flywheel spacer and put a b-series flywheel and stock fork back in it
2fastgsr had a problem at high rpms w/ the evo kit cuz of the flywheel was out of spec
pm bisimoto about your problem
Old Oct 18, 2008 | 11:31 AM
LA_HONDAS's Avatar
that shouldn't be compressed like that
that tells me your flywheel and/or clutch is out of spec
Old Oct 18, 2008 | 12:36 PM
solturbob16sol's Avatar
* B A N N E D *
that clutch fork seems to be a little bent im not sure maybe its the angle
kpjo4
13
Jan 6, 2010 12:47 PM
-Championship-
Sep 12, 2006 01:01 PM
esca
Oct 1, 2004 10:27 AM
range
Dec 1, 2003 02:01 AM
Drag3GSR
Jun 15, 2001 06:01 AM
