Failed state ref. experts needed.
Old Oct 9, 2008 | 11:50 PM
mdj_ge's Avatar
Default Failed state ref. experts needed.
Hey guys I'm in need of your help. Went in to state ref. today, and the car did not pass.
Car / Engine Info :
1995 Honda Civic SI / 2000 GSR swap ( 95 gsr throttle body w/ 95 gsr emission sensors)
Ecu - previously chipped obd1 gsr ecu (w/ j1 jumper wire CUT, and removed chip)
New NGK Iridium IX plugs , 1 year old universal cat.
No engine check.
Here are the results :
Recevied (Modify) Fuel Evaporative Controls due to criss crossing two vacuum lines. Any Help will be appreciated. Thanks
Old Oct 10, 2008 | 12:12 AM
eg:R's Avatar
Default Re: Failed state ref. experts needed. (mdj_ge)
i thought all the state ref. were closed due to buget cut??
replacing the cat. with a good oem one.
Old Oct 10, 2008 | 12:59 AM
mdj_ge's Avatar
Default Re: Failed state ref. experts needed. (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">i thought all the state ref. were closed due to buget cut??
replacing the cat. with a good oem one. </TD></TR></TABLE>
They've just reopen 10/08/2008.
Old Oct 10, 2008 | 10:07 AM
solturbob16sol's Avatar
* B A N N E D *
my guess would be that universal cat is hollowed out
Old Oct 10, 2008 | 02:28 PM
mdj_ge's Avatar
Default Re: Failed state ref. experts needed. (solturbob16sol)
I just got myself a virgin obd1 p72 at a sweet deal, 80 bucks. Next test will be w/ stock gsr cat and ecu. will update after the retest.
Old Oct 11, 2008 | 02:01 AM
dude_123's Avatar
Fix the tampered component as well too. The ref will fail you even if you pass the tailpipe due to tampered emission control. Definitely always run stock components, higher chance of passing emission test.
Old Dec 2, 2008 | 02:26 PM
MugenNSX's Avatar
Did you finally pass state ref? which station did you go to? Any info is great...i'm looking to do this in the next month..
mdj_ge
Oct 10, 2008 11:51 PM
civic99gsr
Oct 12, 2006 11:57 AM
milano2kdc2
May 15, 2006 10:57 PM
dayaftertomorrow
Jan 9, 2006 04:15 PM
Hatch_00
Apr 18, 2003 06:52 AM
