shifter bushing?
Old Oct 18, 2008 | 10:40 PM
corkss's Avatar
Default shifter bushing?
I'm putting my swap together and I was hooking the shifter up to the linkage and the shifter is to narrow between the two pieces of the shift linkage...is there supposed to be a bushing between the shifter and the linkage? Its enough of a gap for a couple washers on both sides! The shifter is a d-series...are b-series wider? Or pics would be helpful too!
Thanks in advance!
Old Oct 19, 2008 | 05:57 AM
LA_HONDAS's Avatar
Default Re: shifter bushing? (corkss)
you need a b-series shift linkage for a b-series swap or h2b swap
Modified by LA_HONDAS at 9:46 AM 10/19/2008
Old Oct 19, 2008 | 07:08 AM
Swipe'd's Avatar
yes theyre are supposed to be spacers there. just put in some washers to fill the gap, but don't tighten that bolt too much or you will have a difficult time moving your shifter.
Old Oct 19, 2008 | 11:02 AM
corkss's Avatar
Default Re: shifter bushing? (Swipe'd)
I do have b series linkages....
Swipe'd..thats exactly the info I was lookin for!
Thaks for the help!!!!!
Da1WiTsKiLz
Sep 26, 2015 04:38 AM
WeakSauceEJ8
Sep 15, 2011 03:38 PM
hctjohnson
Mar 28, 2008 12:45 PM
Bob_760
May 26, 2007 03:45 PM
Sketch_hs
21
Mar 31, 2004 12:51 PM
