CRX-GSR swap: OBD2 throtltle body on OBD1 car?
Old 08-30-2008, 12:55 PM
Ldo
Ldo's Avatar
Default CRX-GSR swap: OBD2 throtltle body on OBD1 car?
In the middle of a swap and realize the IACV and throttle bodyare from OBD2. I'm wiring and running stock P72 OBD1 ECU.
I know they got rid of the FITV and redesigned the IACV, but not sure if the OBD1 ECU will look for them.
Thanks.
Old 08-30-2008, 02:06 PM
kalm_traveler's Avatar
Default Re: CRX-GSR swap: OBD2 throtltle body on OBD1 car? (Ldo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ldo &raquo;</TD></TR><TR><TD CLASS="quote">In the middle of a swap and realize the IACV and throttle bodyare from OBD2. I'm wiring and running stock P72 OBD1 ECU.
Thanks.
If it had an FITV then it will CEL without one plugged in. You should be able to grab any OBD1 FITV and just plug it in (they don't need to be functional, just plugged into the harness). IACV shouldn't be a problem either - make sure it's wired correctly (sometimes Honda switches wire positions in the plugs)
CAVANAGH
09-21-2010 02:15 PM
19CivicSi99
06-17-2007 03:29 PM
gearhead313
03-02-2003 01:44 PM
airon
06-12-2001 03:09 PM
Quick Reply: CRX-GSR swap: OBD2 throtltle body on OBD1 car?
