h2b L bracket in eg
Old Dec 24, 2008 | 05:21 PM
z6hatchboy's Avatar
Default h2b L bracket in eg
Im getting everything together for my h2b, doing my research and all and i believe i need the dc L bracket according to qsd? Is that so? Ill be using the bisimoto or evo h2b kit though but still. The bracket is the one behind the motor/trans the mates to the firewall/subframe right? I know that one sounds noobish but im just making sure haha. thanks
Old Dec 24, 2008 | 06:12 PM
iwanttokillgod's Avatar
Default Re: h2b L bracket in eg
yes you will need the any hydro b series L bracket
Old Dec 24, 2008 | 06:14 PM
2fastGSR's Avatar
King of the One Liners
Not every B series will work.
a 99+ SI bracket WILL NOT WORK.
A 94+ integra T mount is what you need
Old Dec 24, 2008 | 06:21 PM
z6hatchboy's Avatar
Awesome, thats what i was thinking.
how about the throttle cable, i havnt heard much on that. I dont know if thats because the stock d series works or what?
Old Dec 24, 2008 | 07:28 PM
Search-first's Avatar
a D might work, I have an Ls one on mine, just b/c It was on my last motor. you are going to have to make a bracket where it mounts for the slack to be taken out for the throttle blade, I had to customize my skunk2 throttle bracket for my h2b with the Ls throttle cable. For the throttle cable, I don't think there is a real good answer, but like the others said, you need an sir2 or a 94-01 teg rear L bracket.
Old Dec 24, 2008 | 08:00 PM
z6hatchboy's Avatar
Great, just what im looking for. I could fab a simple cable mount with some 1/8 or smaller flat steel or something easy.
Old Dec 25, 2008 | 12:51 AM
SIXTY's Avatar
Thats all you need. Good luck on your project.
Old Dec 25, 2008 | 07:40 AM
turboedsupe's Avatar
Your stock cable will work just flip the bracket on the intake mani around and you have to bend the one on the shock tower down a little. Here is a pic of mines
Old Dec 25, 2008 | 09:10 AM
a 99 si bracket will work thats what im using in my 92 hatch
Old Dec 25, 2008 | 10:56 AM
I also heard the 99-00 si bracket was a little different and wouldnt work. I would just stick to an integra one
Old Dec 25, 2008 | 08:14 PM
Well let's put it this way, a 99-00 Si would be way to short on my setup with the Evolution kit.
Old Dec 25, 2008 | 11:06 PM
DSRxCandyh2bEG's Avatar
are you using a EK crossmember?
Old Aug 31, 2009 | 03:27 PM
juan3023's Avatar
does any one know which L braket will I need if I am useing the qsd kit into a ef chassis ?
Old Aug 31, 2009 | 04:56 PM
Bserious's Avatar
This question gets asked a lot and is our FAQ.
The L (or T as some call it) used is the same one you would use if you were doing a B swap into your chassis. The tranny does not relocate therefore neither does the L (or T) bracket.
So which bracket would you use for a EK with a GSR swap? A 99+ SI bracket is needed, which is also need to do the H2B.
Old Aug 31, 2009 | 10:50 PM
DA rear bracket...
eghatch07
Sep 19, 2014 07:28 PM
purple v8 eatr
Apr 3, 2014 04:00 PM
Keeper1343
Aug 21, 2007 05:49 PM
fantabulous
May 21, 2007 09:59 AM
