D16 block with D15 head?
Old Nov 23, 2008 | 06:37 PM
kauai96's Avatar
Default D16 block with D15 head?
k so im just fooling around bored, i got a d16 and d15. i am trying to swap the d15 head on to the d16 block. both engines are non vtec, i was just wondering if anybody has done this swap? any complications or anything they ran into? let me know. shoots, any input welcome... bam bam
Old Nov 24, 2008 | 11:07 AM
LA_HONDAS's Avatar
i did it
you just have to swap the head
i used the d16 head bolts timing belt and head gasket and it runs like a winner
if i do it another one ill use a y8 head gasket and a 90-91 si cam
Old Nov 25, 2008 | 11:09 AM
kauai96's Avatar
no way, thats sick. how did that work out? could i use d16 valvetrain in the d15 head do you know?
Old Nov 25, 2008 | 11:48 AM
LA_HONDAS's Avatar
think their the same but im not a 100% sure
Old Nov 29, 2008 | 03:17 AM
fc3srx729's Avatar
They are both interchangeable...
Old Nov 29, 2008 | 06:44 PM
civickiller's Avatar
my friend did it, no problems.
adjustable cam gear to set timing
Old Dec 10, 2008 | 04:46 PM
kauai96's Avatar
thanks for the input, i just got the head back from the machinist, bout to put i on, mahalo.
Old Dec 11, 2008 | 04:34 PM
Search-first's Avatar
It's the same head casting, The d16 cam is different, which is what you need to keep in order for the timing to be right. If you keep the d15 cam, which is garbage, then it will be 4.5 degrees out of time and it will be weaker.
Old May 28, 2009 | 12:38 PM
kauai96's Avatar
Default Re: D16 block with D15 head?
You cant re use the cam with the d15 head, the caps are way different,
Old May 28, 2009 | 12:41 PM
kauai96's Avatar
what i did was i used the cam gear off the d16, and i still had to cut the distributor to get the thing in timing. the thing is workin pretty cherry, im just finishing up the turbo for it right no
Old Apr 8, 2024 | 12:41 PM
Damian_91Ee's Avatar
Even though the d15 valve train set up is meant to take a lot more beating than a d16 but it's up to you I have a d15 head on a d16 block and it runs like a champ and acts like if I have a stage 2 a stage 3 clutch on it
low&slowef
Jun 13, 2011 10:11 AM
turbocivic1984
Jun 2, 2008 03:03 PM
Civiclized
Sep 28, 2006 08:46 AM
dohc_profile
14
Mar 30, 2006 12:55 AM
