GSR vs LS
Old Nov 3, 2008 | 07:03 AM
jksmith's Avatar
Default GSR vs LS
i have a bare LS Block and wanting to do a build on it... what pistons can i use? what rods? and what crank?
can i use GSR Rods? How?
what's the difference between the cranks B16, GSR, LS?
I am going to do High Compression build w/ forged internals? Just wanting to know what each setup will do...
Old Nov 3, 2008 | 07:24 AM
LA_HONDAS's Avatar
Default Re: GSR vs LS (jksmith)
if have a ls block use it
pistons- use pistons for whatever crank your gonna use and if you gonna do ls/vtec you use ls/vtec pistons
rods- get the rods for the crank your gonna use
crank- b16 crank =77mm stroke, gsr crank = 87.2 mm stroke, ls/b20 crank = 89mm stroke
what stock crank will be better , ls/b20 crank will be
Modified by LA_HONDAS at 10:31 AM 11/3/2008
Old Nov 3, 2008 | 11:14 AM
jksmith's Avatar
thanks
94civicgsr
Mar 6, 2011 08:00 PM
VtecRexy
Oct 8, 2006 02:31 PM
b18psi
Sep 20, 2006 04:15 PM
EF9SIRJeff
Aug 24, 2005 11:07 AM
JUNcr-x
Apr 3, 2003 07:11 AM
