K20
Old Jan 10, 2009 | 09:02 PM
em1_civicsi's Avatar
Default K20
Okay Im just wondering what all is needed to go K in a em1.
-Hasport engine/tranny mounts
-K20a3(ep3/rsx base) engine
-k20a2 tranny (rsx-s 6speed)
-K20a3(ep3/rsx base) engine harness
-ep3/rsx stock ecu or Kpro either one
-em2/rsx shifter box and cables
-RBC intake manifold (flow better/more whp/tq)
-Intake
-Header
-Custom cat back exhaust
Im just not sure abour this.
-Hasport axles or can I use ep3/rsx? Im guessing no since there suspension then I read something about using integra axles but Im not sure how they would work? do they?
what am I missing? thanks
Old Jan 10, 2009 | 09:22 PM
ekb16's Avatar
Default Re: K20
www.k20a.org for more info
u can use stock k series axles but u need to change the outter to b series to fix ur stock axle hub
Old Jan 11, 2009 | 08:37 AM
Search-first's Avatar
Default Re: K20
You sure you want to do an A3? kind of a waste of money, unless you just like the look of a K, without the performance of its bigger brothers.
Old Jan 11, 2009 | 12:08 PM
Default Re: K20
Well right now my Em1 has a b16a
I took this from wikipedia
K20a3
  • Power: 160(120 kW) @ 6500 rpm
  • Torque: 142 lb·ft (193 N·m)* (191 N·m) @ 4000 rpm
B16a
  • Power: 170 hp (130 kW) @ 7800 rpm
  • Torque: 116 ft·lbf (157 N·m) @ 7300 rpm
with the RBC mani on the a3 and I/H/E
I should be at a good WHP/TQ which Ill be happy with
Plus it's mostly the WOW your Kswapped
Hell A stock b18c5 put a smile on my face and
I've driven my friends k24/20 swapped civic and
my other friends k20a2 swapped both with Kpro & I/H/E
and I dont need the extra power. Plus a k20a3 is cheap to buy
Plus I have about 2k right now set aside to build the b16 but
I can save alittle more and swap a K into the car I always find good deals on the net and my friends and I can do the swap. so I shouldnt have too much into the swap
but dont get me wrong I wont be doing this soon I wanna finsih the car before I do another swap
Old Jan 11, 2009 | 01:06 PM
kid-honda's Avatar
Default Re: K20
Dont listen to this, same BS was said about non vtec and sohc motors years ago and look at them now.
It will make a great street motor for a good price, I say go for it.
Plenty of aftermarket support for it and you can always turn it into a better motor down the line with a head swap and some oem bottom end parts if you want.
Old Jan 12, 2009 | 06:52 AM
Andres-eh2's Avatar
Default Re: K20
It's a waste of time and money doing a a3. I would go a straight k24 instead. The problem is that you're still spending a ton of money on the k swap parts (which is a fixed cost no matter what k motor you go with) while only just saving a little getting an a3 with very little power (which is the variable in the equation). So I do understand what the guy above is saying about b and d series but k is another league. But hey do what you want. In the long run im pretty sure you'd want more power.
Old Jan 12, 2009 | 08:50 AM
Default Re: K20
yepp
its cool i just wanted to know if I listed all the parts I need for the swap or am i missing parts.
Old Jan 12, 2009 | 09:44 AM
Andres-eh2's Avatar
Default Re: K20
ok. you're missing a lot of parts.
Old Jan 12, 2009 | 09:59 AM
Default Re: K20
like what parts?
and when i said k20a3 i mean complete with starter and all the lil bs
Old Jan 18, 2009 | 12:43 AM
fergs96integra's Avatar
Default Re: K20
Seriously i was asking the same thing when i started to do my a2 swap, k20a.org is were its at to get information on this. Go their and you will find out alot. They have lists of everything you need for it as well, also ask your friends with their kswaps what they used, its the same for your motor.
Old Jan 27, 2009 | 06:18 AM
Bseriescivic5's Avatar
Default Re: K20
I have a mint k20a3 sellin CRACK HEAD cheap (complete swap) get that, boost it and CRUSH any of the "big brothers" Just my .02
samnizzle
Honda Civic (2001 - 2005)
16
Jan 23, 2009 04:34 PM
dkim48
Dec 27, 2008 06:23 PM
Crank
Northern California (Sales)
Nov 1, 2006 02:23 AM
turbob18a1
Aug 2, 2003 02:36 AM
