help! 00 civ Ex w/ JDM b18c swap
Old 01-17-2009, 06:45 PM
Pullig's Avatar
Default help! 00 civ Ex w/ JDM b18c swap
I need help cannot get started it just turns over and backfires.... Check plugs got fuel and checked firing order its good too...
Im using p73 ecu ... i used stock ex harness and cut off stock dizzy plug and swapped for integra distributor plug... i color matched each wire and had 1 blue wire left. im at my end with this someone please help
Old 01-17-2009, 08:57 PM
dohcem1's Avatar
Default Re: help! 00 civ Ex w/ JDM b18c swap
Well, my PERSONAL experience... when I was doing my h22 swap, I had someone crank the car while I was outside adjusting the distributor timing. After a while it started nicely. Maybe the engine is flooded with fuel and stuff also. Someone correct me if any info is wrong. this was just what I DID
dohcem1's Avatar
By the way the blue wire is for the TACH
Old 01-17-2009, 09:03 PM
slowcivic e g's Avatar
getting spark all the time?
Old 01-20-2009, 06:56 PM
iliv2xlr8's Avatar
Backfiring is usually a timing issue.
The distributor plug sounds suspicious. You should definitely confirm the wires. Look at a wiring diagram for both cars and you should be able to figure out if the wiring is accurate. Matching the colors may not be that simple.
Next, put a timing light on it and confirm correct base timing. You may be a tooth off if you pulled the distributor. As mentioned before, make sure you are getting consistent spark.
Adam_0115
04-14-2016 05:11 AM
scoker83
05-03-2014 10:16 PM
GetawayInMoscow
06-24-2009 03:07 PM
FyReo3
14
06-21-2005 06:41 AM
WuRKD b16
05-20-2004 11:15 AM
Quick Reply: help! 00 civ Ex w/ JDM b18c swap
