G23 build... any tips
alright im doin an G23 build and its my frist honda swap so if any one has some tips i sould know that would help alot....... thanks
Re: G23 build... any tips
couldnt u still do h2b with the g23? i thought h2b kits matched up to the f blocks too... how much more power does this setup make over the jdmh22a?
well the bare bone G23 makes 200+ HP and with the right parts you could get close to 300 HP, and yes the bolt pattarn is the same on the F and H blocks so you can use an H2B kit
so here's a new idea..... i'm almost done with the G23 so then a buddy of mine did so lookin around and found out that an AWD conversion is very possible.... so what do y'all think
http://www.importtuner.com/tech/impp...dge/index.html
heres a article about the bolisbuilt g23.......idk if it helps??
