How to drop motor from bottom
What steps are involved in dropping the motor from the bottom. I have access to an engine hoist and frame contact hoist. Since i've heard its easier to remove the engine from the bottom i thought i'd ask how.
B-series motor
B-series motor
Re: How to drop motor from bottom
Mechanically it is exactly the same as pulling the engine out from the top, disconnect wiring, fuel lines, exhaust, axles etc. I built myself a low platform from 1x1 square tubing with a plywood deck and casters on the bottom. I put that under the engine/trans, then use a jack to set the engine/trans down on the platform and then pull the mounts. After that just jack the car up and roll the engine/trans out from under.
I have found this is the easiest way for me to do it without having a hoist take up space in my garage.
i usually just hook the motor on to my hoist. lower it down to the ground on to a rubber maid container lid. jack the car up and pull it out.
putting the motor in the same way. but in reverse order.
whats the tip? leave the shift lever with it? oh ok and use a movers dolly too. thanks.
Do i have to move any ABS lines and crossmember? Its a B17
Just did it today. I use my craftsman 1.5 ton aluminum jack with one 2x4 on top. I jack the front end first then place a 2x4 on the jack and jack it up from the driver side. On the driver side i just left a jack stand under the car.If you use a movers dolly like i did you need a 2x4 on the jack for it to clear. If you drop it on the ground you wont need it but its a pain in the *** to move the motor out.
you cannot drop it with the rear bracket, passager, or drivers side bracket on.. I don't have abs so I don't know but i guess you can drop it without removeing the abs....
hailchristian
16
07-11-2009 04:39 AM
Lost_clearance
05-29-2006 06:41 PM
