95 Hatch Swap Mount Question
I have a 95 Eg hatch, I also have a B16a with a Ys1 lsd cable tranny. I plan on purchasing the EGBCC kit from Hasport so I can use the transmission in my hydraulic clutch car.
The EG Civic has 5 mounts, yes? Top/valve cover, A/C bracket, front tranny, top tranny, and rear mount.
The YS1 does not have the mounting holes for the front tranny mount. This is a problem. I'm no stranger to fabrication and I can always think creatively to solve a problem but I figured I'd ask around to see if anyone has figured out a better way.
Pictures are as always very helpful for further suggestions.
This is the general area of the "missing" mount. VVV
H-T Premium Sponsor
the cable transmission does not have the bosses on the front of the case for the lower transmission bracket plus the cable arm would get in the way.
you will be fine running the EGBCC mount with the other civic mounts.
CapnKrunch
09-01-2010 07:19 AM
Ktbolin
04-07-2004 05:20 PM
