Few questions on bseries hybrid parts
Hey guys, im really knew to building engines and i was curious about a few things. i was wanted to know if there was a difference between bseries OEM rocker arms and push rods, more specifically which rockers and push rods perform better? (if there is a difference)
Is it worth investing in aftermarket rocker arms and push rods?
Also i heard that the b16 OBD0 Vtec solenoid works best is this true?
Are bseries intake/exaust valves all the same diameter? can they be interchangeable? (obviously intake valves are larger than exaust valves)
What i mean is if b16b, b16a2, b17 valves were bigger then b16a, or if you can put b18 vtec valves on a b16a head.
I would really like it if anybody opens this topic jus to say that ppl are noobs and this that and the third keep those coments to themselves. Last time i checked forums like H-T were for enthusiast like me to learn more. Thanks for your help guys.
Last edited by tuerka_racing1; 01-04-2009 at 06:25 PM. Reason: misunderstood information
i ♥ snails
Re: Few questions on bseries hybrid parts
no push rods, no aftermarket rockers what the hell?
intake larger than exhaust, yes
not same diameter non vtecs are smaller
read the forum, there is so much info floating around on h-t
oh s*** my typo i meant intake are larger than exaust.
About the interchangable valves, what i meant was if b16b, b16a2, b17 valves were bigger then b16a, or if you can put b18 vtec valves on a b16a head.
but thanks for your response.
