Tuning ls/turbo crx
A lot of dyno tuners don't tune obd0 systems anymore. Contact your local dyno tuners for information on this.
If you require to upgrade from obd0 to obd1 you will need an obd1 distributor, obd0 to obd1 harness & distributor jumper along with an obd1 chipped ecu running which ever engine management system your tuner supports.
If my ls is obd0 i could get these then get it tuned right?
_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a3Q7c39Q 3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZi tem380086002544QQitemZ380086002544QQptZMotorsQ5fCa rQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Civic...3A1|240%3A1318
Re: Tuning ls/turbo crx
You do not need a distributor jumper, but it makes it convenient. You can use either an OBD1 or OBD2 distributor. If your ecu tuner has disabled the O2 sensor, then you do not need the four wire O2 sensor as Mtber has stated. I highly recommend getting a quality ecu harness, distributor and ecu as wiring is something overlooked and cheaped out on so many times. First time you need a tow or have to pay someone to fix the mistakes, you will thank me.
http://rywire.com/store/obd0-obd1-co...23a1f910b2aab3
http://rywire.com/store/-c-32.html?o...610cccb73e6630
ryanangelo212
03-18-2013 12:23 AM
