f22b with p28?
Old Nov 20, 2008 | 08:52 PM
EF_monster's Avatar
Default f22b with p28?
i am planning on doing an f22b swap into my eg. I have a p28 that im gonna send to phearable to get chipped for the swap. i have been doing some research and found out that in order for this to work right i will have to swap pins a6 and a11.
on some of the threads that i have read some people have ran them without swapping and others say you have too. Thats where it confuses me.
my questions:
what exactly do they mean by swapping pins? Do they mean switching them around?
if i send it to get chipped with an f22b basemap will i still have to swap pins?
If i dont swap pins will the car run like crap?
any input is appreciated
Old Nov 21, 2008 | 05:19 AM
kp's Avatar
kp
I'm not familiar with this swap at all, but I can tell you that swapping pins is simply pulling specific wires from the ecu plugs and switching them to a different position. In this case, you pull A6 (6th pin on the A connector), pull a11(the 11th pin on the A connector) and switch them.
Old Nov 21, 2008 | 05:38 AM
LA_HONDAS's Avatar
ecu pinouts http://ff-squad.com/technet/wiring.obd1.htm
ecu pin removal http://ff-squad.com/tech/wiring/obd1.pin_removal.jpg
Old Nov 21, 2008 | 04:41 PM
EF_monster's Avatar
thanks for the replies guys it really helped. After doing more searching i have found out that in an accord you do have to switch the pins. My eg is a vx with a p28. I still dont get why you would have to switch the pins on a civic. It does have egr and i know that for the o2 i have to convert to 4 wire.
would i be able to run my p28 without changing around wires?
Old Nov 21, 2008 | 04:50 PM
LA_HONDAS's Avatar
pm katman or rywire
gotta add some wires for the o2, vtec, vtec pressure
Old Nov 21, 2008 | 05:20 PM
EF_monster's Avatar
ya ive done enough research to know what all i need to do, but when i started lookin for what ecu to use it just stumped me.
thanks i will try to pm those people.
Old Nov 21, 2008 | 05:44 PM
LA_HONDAS's Avatar
you aint gotta be a smartass
Old Nov 22, 2008 | 07:58 AM
EF_monster's Avatar
sorry i didnt mean to sound like a smart ***, i really do appreciate the help.
Old Nov 22, 2008 | 09:28 AM
ashb82's Avatar
i did a f22b1 swap in my eg civic i did not swap any pins out. i used the civic engine wiring harness and just plugged in chipped p28 worked fine.need any help i will help as much as i can
Old Nov 23, 2008 | 06:44 PM
Rob_O's Avatar
Use the civic harness like ash did and you won't have to swap any pins around
grandam
May 16, 2007 08:03 PM
delslowhonda
Apr 29, 2006 03:38 PM
hahagasdcrx
Aug 18, 2004 11:54 AM
