why is my motor missing.
Old Dec 1, 2008 | 09:38 AM
ISawUL00k's Avatar
Default why is my motor missing.
i am running and OBD II LS integra motor swap in a 92 vx. i have a 0bd I integra harness and p75 ecu and i also have converted my injectors..i left the obd 2 manifold and throttle body on. is this a bad combo.. does this work ?
it idles ruff AND dies if i gas it mainly it misses like the dizz is messed up or bad but i have replace d it with 3 different dizz, and ecu./
Old Dec 1, 2008 | 10:10 AM
LA_HONDAS's Avatar
i had that problem and it was the map sensor wired up wrong
make sure the tps and map sensor plugs are not mixed up
Old Dec 1, 2008 | 03:30 PM
4drteg54321's Avatar
Am having the same problem. Ill tell you what happen when i fix it.
Old Dec 1, 2008 | 03:36 PM
Rob_O's Avatar
Yeah, my money is on a couple sensor plugs swapped. Very simple and common mistake I've made myself
Check the wire colors on each plug, make sure they are correct ones for that plug
Old Dec 2, 2008 | 09:00 PM
I fix my problem it was the ECU, i got the right ecu for my motor.
Old Dec 3, 2008 | 06:08 AM
LA_HONDAS's Avatar
well he said he try 3 ecu
i say its the wiring
Old Dec 6, 2008 | 06:25 PM
fumatch's Avatar
why did u convert your injectors? obd1/obd2 are all saturated injectors (no resistor box)
http://hondaswap.com/general-tech-ar...jectors-30347/
Old Dec 25, 2008 | 03:09 PM
Default Re: why is my motor missing.
well my problem is back i only worked once. Anyone have a answer to the problem?
Old Dec 25, 2008 | 03:11 PM
i switch them and they did nothing
Old Dec 25, 2008 | 03:14 PM
how esle can the map sensor be wired up?
moemoney
Sep 7, 2011 10:33 AM
one slooow dc4
Nov 15, 2009 06:39 PM
dan617
Dec 23, 2008 10:51 PM
RuffRhyno
Sep 3, 2002 08:51 AM
