Bottom end bolts from a b16 to a b18b
Old 01-01-2009, 01:32 PM
Boostage's Avatar
Default Bottom end bolts from a b16 to a b18b
I have a bare b18b bare block and crank with main caps, oil pick up, baffle etc. but I am missing some of the bolts. mainly some of the longer bolts that hold down the caps. if I buy a complete b16 swap to help make an ls/vtec out of this motor, can I use the bolts from the b16? to my knowledge it should all be the same.
Old 01-01-2009, 09:46 PM
integrawow's Avatar
Default Re: Bottom end bolts from a b16 to a b18b
If you are referring to the main caps, then no, you cannot use the B16 ones. The reason why is because the B16 uses a main girdle which makes the required bolt length that much longer than a motor (B18b) without a main girdle.
I hope this helps. I am pretty darned sure that i'm right. If I am not, then that would surprise the heck out of me.
Old 01-01-2009, 11:47 PM
Boostage's Avatar
I dont think the b16 has a girdle, just the b18c
Old 01-02-2009, 06:46 PM
Furyof4's Avatar
Correct. No girdle on b16a's.
Boostage, just buy the bolts you're missing new from Honda. They're not that expensive.
mhart
05-04-2009 09:12 AM
Suck my DX
12
06-01-2007 02:43 PM
Vance
11-15-2006 06:04 PM
Slimm-rw-
12-14-2004 07:33 AM
Quick Reply: Bottom end bolts from a b16 to a b18b
