H2B Help
Old Nov 6, 2008 | 09:03 PM
DC2 Maggio's Avatar
Default H2B Help
Hey guys I just need a bit of input,
I currently have an H22A installed in my 95 DC2 Integra. I am using Hasport Mounts. I am very interested in doing the H2B conversion. Just looking for a bit of input on how much work it would be to do this swap since I have already made the adjustments for the h series swap (cutting the floor, mounts, etc). Just wondering how hard this will be in my situation. Thanks alot
Old Nov 7, 2008 | 05:20 AM
2fastGSR's Avatar
King of the One Liners
Default Re: H2B Help (DC2 Maggio)
re-weld pass mount, re-weld floor board
Old Nov 7, 2008 | 07:09 AM
DC2 Maggio's Avatar
I can't use my hasport mounts with the QSD kit correct? I know I need a b series tranny mount but not sure about the rest with the QSD kit.
Old Nov 7, 2008 | 07:31 AM
2fastGSR's Avatar
Default Re: (DC2 Maggio)
need b series mounts , not h series
94+ integra T mount for an EG
99+ SI T mount for an EK
Old Nov 7, 2008 | 11:05 AM
DC2 Maggio's Avatar
so i need to sell my h series mounts and make my 22 sit on b series mounts? sorry im such a noob at this swap
Old Nov 7, 2008 | 12:09 PM
RotiEatter's Avatar
Ditto
Yeah, sell your H-series mounts, axles, and int. shaft.
Get B-series mounts, axles, and int. shaft.
<--- 4 1 6. I was born in Toronto.
Old Nov 7, 2008 | 09:42 PM
YeeJ6's Avatar
yup. just sell your h series mounts, linkage, axles, trans. the QSD h2b kit is ALL bseries from the flywheel back. mounts, linkage, intermediate shaft, axles.. blah blah, its all b series. and like 2fastgsr said, just reweld the bracket and fill the hole in your floor board. i went from h22 to h2b(ej6 chassis) and it wasnt hard at all. i just found a donor ek for my floor board peice and i was set.
to answer your question, it is not hard
Old Nov 8, 2008 | 10:53 AM
DC2 Maggio's Avatar
thanks alot guys for your input. so i just purchase the hasport b series stock replacement mount set for my dc2 correct? (plus all the other things i need)
Hows the qsd kit goin for you guys anyway?
Old Nov 8, 2008 | 11:03 AM
YeeJ6's Avatar
yup. those are the right mounts.
I love the qsd kit. i havnt had a single problem
Old Nov 8, 2008 | 11:44 AM
DC2 Maggio's Avatar
So b series axels will fit for my dc2? im not sure what you used in the Ek
Old Nov 8, 2008 | 11:51 AM
DC2 Maggio's Avatar
it says ek in ur sig but u said ej6 so either or lol nice avatar by the way lmao
Old Nov 8, 2008 | 12:14 PM
YeeJ6's Avatar
haha thanks. yea, any b series integra axles and intermediate shaft will work just fine. same goes for your shift linkage.
Old Nov 8, 2008 | 12:27 PM
DC2 Maggio's Avatar
sent you a im. but thats just weird picturing a h22 sitting on b series motor mounts. i didnt think it was possible. i guess with the engine bracket or w.e they give you it is.
Old Nov 8, 2008 | 12:39 PM
YeeJ6's Avatar
heres a pic of the driver side bracket for the h2b
Old Nov 9, 2008 | 07:19 AM
DC2 Maggio's Avatar
thanks alot guys time to purcahse me a qsd kit, mounts, etc. now time to go hunting for a good header
Old Nov 11, 2008 | 05:53 AM
sicc22's Avatar
Default Re: (YeeJ6)
might wana replace that auto tensioner. just sayin
Old Nov 11, 2008 | 09:48 AM
Tweek-B16's Avatar
can i use a chipped p28 ECU with a h22a (J-spec) basemap? or what kind of map?
Old Nov 11, 2008 | 02:37 PM
turboedsupe's Avatar
Default Re: (Tweek-B16)
Yes you can, thats what i used until i got my real tune done. Just be careful depending on your mods you might run a little lean. I wouldnt race on it just use it to drive normal and break everything in then get it tuned. Make sure you run 91 too jdm has 10.6 compression
Old Nov 13, 2008 | 10:29 AM
Tweek-B16's Avatar
the problem is that its hard to find anybody in germany who optimize or tune this ecu correctly because i dont know that enybody did this swap ever.
eg_21
Jun 8, 2009 07:54 PM
92egboost
Jul 18, 2008 07:02 AM
joey1320
Nov 15, 2004 06:20 PM
Neondog82
Aug 27, 2004 03:01 AM
ForceFed Coupe
Dec 13, 2003 04:19 PM
