98 cr-v w/ jdm b20?
98 cr-v w/ jdm b20?
it looks like it is a whole lot easier to find a b20b instead the stock factory us spec b20 i was wondering is there any modification i have to do to put the jdm motor into my 98 crv? or everything is straight plug n play?
Re: 98 cr-v w/ jdm b20?
Wrong. JDM engines dont use a CKF sensor. (Crank Fluctuation sensor)
Meaning, you will throw a CEL code (#56 if i remember right)
You can do one of two things, You can swapthe JDM oil pump, for its USDM counterpart, and utilize the CKF sensor, or find out how to do the bypass trick, Which works somethimes. Ive herd of people doing it and still having problems.
