wiring for a 91 ls motor in 89 civic si
New User
i ve heard that the integra engine wiring just plugs up to the civic harness. but ive also heard of people using the si engine and extending some wirings for curtain sensors. i want to use the most reliable setup. does the integra ecu use the same plugs as the civic ecu? please help me if you have any tips if youve dont this swap before
thanks
thanks
Re: wiring for a 91 ls motor in 89 civic si (tlieu88)
hmm...who told you that the integra harness plugs right in?....from my experiences...it doesnt....you have to use the si harness....but the ecu does plug right in...as long as its from a 90-91 integra....good luck
New User
thanks for the inform. i know what parts i need for this swap, does anyone have any tips to makes this swap go smooth.
Easiest b series swap, just wrap your harness and plug it in before you put the motor in, makes it a little easier. Other than that it is straight forward.
Re: wiring for a 91 ls motor in 89 civic si (hybridrex)
Best thing I can say is to look befor you start the project for the needed parts, then get them in advance, also get some good tools, they will be usefull, be shure!!
good luck dude!
good luck dude!
kenneth4g4d
11
06-15-2014 11:21 AM
PDRIFT86
04-11-2007 09:20 PM
slammedef06
12-29-2005 10:42 AM
