2 engine swaps in one....or not
Old Dec 17, 2001 | 06:31 AM
ben_vtec's Avatar
New User
Default 2 engine swaps in one....or not
i currently have a eg6 with a uk spec b16a2 (no lsd) and a ef with uk spec d16a9. i am planning to turbo the eg and was thinking about putting in a b18c1 and a lsd tranny. i will then have a b16 engine and box but no alternator starter etc as these will still be on the eg6.
would i be better off using the b16a2 in my EF and buying the extra bits to get it to run?
trying to get a 1.8 with all the bits so i can use the 1.6 with its parts in the EF?
or selling my b16a2 and buying a complete conversion from wrote off crx/civic (EF) vtec (we get the twin cam vtec civics here) for about £500.
could anyone list all of the parts to do the vtec conversion to a d16a9 EF (or even direct me to a previous post-ive tried the search with no luck)
EF for work
EG for play
p.s. any decentish cheapish exhaust recomendations for my EF would be very welcome
Old Dec 17, 2001 | 06:42 AM
ben_vtec's Avatar
New User
Default Re: 2 engine swaps in one....or not (ben_vtec)
just a thought. dont suppose the d16a9 tranny will fit to the b16a2 engine?
if not, would a b16a tranny mount to a b16a2?
are there many diferences between a b16a and a b16a2 (externally)
Old Dec 17, 2001 | 10:09 AM
RedlinedVTEC's Avatar
Uh d series trannies don't fit b series blocks. Of course a B16a tranny will fit on your b16a block. Difference between the b16a1 (non obd) and b16a2 is mostly obd related stuff. Oh yeah the b16a1 came with a cable tranny. Just get the tranny right for your chasis... EF = cable EG+ = hydro.
Old Dec 17, 2001 | 10:10 AM
90accord1's Avatar
an b sereies tranny will bolt to any b series block, the d series tranny wont work on the b16a2, and no there are prolly not many differences externally besides wiring harness.
Old Dec 21, 2001 | 05:22 AM
ben_vtec's Avatar
New User
Default Re: 2 engine swaps in one....or not (90accord1)
would it be as easy to use a b16a2 as a b16a1 in a 4th gen?
Old Dec 21, 2001 | 04:55 PM
1.8EG-T's Avatar
The 1st gen jdm b16 is easier for the EF, but you need to realize that there are difference's in the clutch disc between the 2 trannies. That is between the jdm 1st gen b16 and the 2nd gen and up b16's.
Old Dec 26, 2001 | 11:37 AM
SpooN Man's Avatar
Default Re: 2 engine swaps in one....or not (hybridrex)
have fun putting a hydro in the EF,
ha ha ha
get a j1 or s1 and sell the hydro.
The swap should work. You can convert a obd2 to obd1 or 0 no problem. You will need a few things. Injectors, distro, ef harness. and alot more
Charlie Moua
10
Aug 10, 2017 09:45 PM
Jaydm EK
Appearance Build Threads
411
Jul 3, 2012 10:17 AM
tonylovesjdmEF9
Jan 10, 2012 08:03 PM
JDM*JUNKY*EF9
Nov 8, 2011 10:27 AM
crazykamper
Jan 10, 2007 03:21 PM
