JDM B16 map sensor, EVAP q's
Old Dec 7, 2001 | 05:32 PM
kangjin's Avatar
Default JDM B16 map sensor, EVAP q's
just comparing the d16 and the b16, there's no spot on the top of the b16 tb for the map sensor...and on the back of the manifold, there's no tap or hole for the evap...this has probably already been covered, but i can't find anything on it...
what do i do? just bypass them both? help!
Old Dec 8, 2001 | 04:30 PM
rioninja's Avatar
Default Re: JDM B16 map sensor, EVAP q's (kangjin)
Simple solution to both problems. For the evap, just buy a t-fitting and tap into the vacuum line for the fuel pressure regulator. Also, you'll see a port on the throttle body where the map sensor is on your stock motor. On older civics the map sensor is on the firewall, and connected to the TB by a vacuum hose. Just go the the junkyard and get any 88+ map, your stock wiring will plug right in. then just run a hose to the TB.
Old Dec 8, 2001 | 04:31 PM
rioninja's Avatar
Also, if anyone needs a map sensor i have one for sale. $15 plus shipping.
Old Dec 8, 2001 | 05:45 PM
rainforest's Avatar
Default Re: JDM B16 map sensor, EVAP q's (RioNinja)
yeah your b16a must be a 1st gen the second gens have electronic map sensor and your is seen by vacume....
Old Dec 8, 2001 | 06:06 PM
kangjin's Avatar
how can i tell if it's a first gen? it's a 5xxxx series block, and connected to a hydro tranny...what else tells? btw, i got the swap from jdmhondaparts...
Old Dec 8, 2001 | 06:12 PM
kangjin's Avatar
oh yeah, it was supposed to be a 95 jdm b16, and i have a 94 civic w/d16z6.
and on the valve cover, the VTEC is bigger than DOHC...
...but on the throttle body, there is no hole on the top for the map sensor, but there is are two outlets, a larger one and a smaller one...does anyone have a good pic of what the top of a 2nd gen b16 tb looks like?
Old Dec 8, 2001 | 10:49 PM
rioninja's Avatar
Default Re: JDM B16 map sensor, EVAP q's (rainforest)
rainforest, you are incorrect. Not all second gen motors have throttle body mounted maps. Also, both map sensors are 100% identicle, only difference is one is directly mounted and one is mounted on the firewall and connected by vacuum hose.
bodiez
Oct 26, 2010 02:17 PM
jw15u
Nov 14, 2009 06:57 PM
Brian Hinson
13
Jun 24, 2006 04:05 PM
88crxhfb16
Apr 16, 2005 05:59 PM
Yellow Dragon
Jul 23, 2003 02:01 PM
