H22, what belt to use?
New User
I'm doing my H22 swap to a 97 Civic hatch. What belt do you guys use on the motor? I took off the power steering and AC compressor. I just need the belt that goes to under pulley to the alternator. What is the part number and where you purchase the belt? Thanks in advance.
Re: H22, what belt to use? (MrPimpon)
just use a tape measure and wrap it around the pulley, on the motor, and then around the other pulley. then count the groves in the pulley and take that number and the number on the tape measure and go to napa, or what ever your auto parts store is, and tell them, how long, and how many groves. make sure you have the adjustment as small as it goes so you can adj your belt over time.
HTH
HTH
Re: H22, what belt to use? (cccya)
or to be somewhat more precise (kinda).. just use a piece of string...... mark it.. then measure it.. either way you get the same results.. OR just do what I did.. buy a chit load of them and just return em all.. heh..
Re: H22, what belt to use? (Xav H22EG8)
Silvertc
06-15-2008 06:12 AM
ozzyman
09-17-2003 07:00 PM
