b18b crx.. stalls and dies...
i swap a automatic b18b motor using a 91 usdm s1 tranny, non odb ls distributor and ecu into my crx hf, the problem is it that when i rev the car, the rpm will drop and stalls down to 200 and dies out.. i've check the timing, plug wires, and plugs, im throwing a code 7 for the tps sensor, also my idle is at 300+50.. what can i fix this
Re: b18b crx.. stalls and dies... (pg_thao)
im using the 95 ls tb.. and yea the tps is in, also, the car will rev up to 2 and come back down and die.. i really need help
H23vtecEG
01-28-2003 07:20 PM
