check engine light after swap
Old Dec 4, 2001 | 09:14 PM
milo's Avatar
Default check engine light after swap
just did a swap (94 civic dx/gsr motor) and everytime after starting the car, the check engine light comes on after a minute or so...any input would be great.. thanks...
Old Dec 5, 2001 | 02:32 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: check engine light after swap (milo)
what is the code????
22???
Old Dec 5, 2001 | 07:56 AM
HKxBlur's Avatar
mista, u have VTEC problems with your swap? 22 is VTEC for OBD1-2..
Me, I've been rolling the EVAP code since the swap, and occasionally the o2 code when I'm open.. Other than that the swap went without a hitch..
If u can provide the trouble code and what year motor, we'd be able to assist u alot more.. If u have no idea how to get this code and if u don't have a Game Genie, email me and I let u know how to..
Old Dec 5, 2001 | 09:48 AM
milo's Avatar
Default Re: check engine light after swap (HKxBlur)
if my 02 sensor is not hooked up right, this will cause the check engine light to come on, right?? thanks again..
Old Dec 5, 2001 | 01:02 PM
fowler!'s Avatar
yes. have you checked your codes yet?
Old Dec 5, 2001 | 06:27 PM
milo's Avatar
Default Re: check engine light after swap (fowler)
yes i have..its giving me 21...the book says it's related to vtec solenoid.. i checked the grounding and everything...i think im not having good continuity on the wires i plugged into the ecu harness (A4 esp).. what's the best way to do it???
Hatchman98
Dec 26, 2006 08:51 PM
LsVtec98
Feb 17, 2005 04:09 AM
type Gendy
Apr 21, 2003 04:48 PM
lonefuzzy79
Jul 30, 2002 05:24 PM
