ZC rev problems
Old Dec 12, 2001 | 11:40 AM
hahagasdcrx's Avatar
Default ZC rev problems
zc in a 88 hb the engine starts and idles fine but you can punch the gas and it revs all the way to the redline with ease but slowly give it some gas and the engine stumbles like its hitting the rev limiter at only 1500 rpm no codes on ECU dx-si wiring all correct new dist well hell new everything so someone help me out???
Old Dec 12, 2001 | 12:39 PM
91civicguy's Avatar
New User
Default Re: ZC rev problems (90crxzcgasd)
I know when I put a zc in my civic it did the same sort of thing. Mine only did it until it was up to full operating temperature. It was like it was bogging out when I tried to get on the gas alittle bit. I set the timming to stock specs and that helped a little. It always still did that everyonce in awhile. The mechanic at my local shop said that it was running rich.
Old Dec 13, 2001 | 05:04 AM
jdm_ef9's Avatar
Default Re: ZC rev problems (91civicguy)
what ecu are you using? i know that the 89 teg ecu will cause your car to run really rich. the only problem i had putting mine in was the vacuum lines, but i got them all right now! id say check your vacuum lines, thats my opinion though. good luck!!!
sircrxracer
12
Apr 29, 2005 04:04 AM
integ u
24
Mar 11, 2004 05:01 PM
Outsane
15
Feb 25, 2003 10:01 AM
civteg1
Mar 1, 2002 05:32 AM
