shaking h22civic..need help!!!
i just finished my swap h22 swap in my eg and went out for a test drive and the car was shaking like crazy, cant even go over 20mph or it seems like the cars gonna fall apart...im using the hasport mount kit with accord shafts and 90-93 integ axles.....but i talked to my friend and he said i might have been given the wrong axle??? and suggestions or help?? thanks
New User
Re: shaking h22civic..need help!!! (prjctCIVIC)
if it shakes when your in not driving and giving it some gas i would think its in the mounts .if it shakes while going down the road its going to be the axels.when
i changed my axels out for the first time i thought i had tighten them up tight ,where they bolt up at the rotor and stuff but i didnt .my car was shaking like crazy .so i tighen em up more and the car was fine .if you had the wrong axels you usually can tell while installing them ,but you never know .try retighting the axels or make sure there tight .just my 2 cents , good luck ,....
DRoszyk
10-26-2010 02:42 PM
