VTEC WIRING
I've just completed my swap and I have a bit of a small problem here. I am trying to wire up my Vtec. I have a 94 Civic Dx with an 88-91 B16a motor and using a reprogrammed P28 ecu. I know that the P28 doesn't detect a knock sensor, so I don't need to run that wire. I ran the Vtec Valve solenoid into A4, Vtec oil pressure into D6, and I am not sure where I need to run the other wires. If someone can give me a well detailed description of how the wires are ran, I will soon get started on it. Also, I am playing plug and play with running vacuum hoses correctly with the older gen b16a also. Thanks.
Pictures posted will be great.
