Throttle cable, and radiator hose questions.
B16 into a 6th gen coupe.
I noticed today that the radiator hose is bigger than the flange on my radiator. any idea what I should do about this? Will clamping the S out of it work?
also the throttle cable is too short, I tried turning the bracket around to get it to work, but it is like 5mm too short. its real close, so I there should be a way to get it to work...what did everyone else do for this.
Re: Throttle cable, and radiator hose questions. (DragIIcivic)
sure u got the right readiator hose ? i woudlnt use it, and clamp the **** out of it, expect leaks from it.......
Re: Throttle cable, and radiator hose questions. (hybrider93)
it's the hose straight off the B16...the stock hose won't fit because the other end is too big...
Re: Throttle cable, and radiator hose questions. (EG-cellent)
The throttle cable for an SI should work for you.
Re: Throttle cable, and radiator hose questions. (fixhondas)
you can do what he said ^ or you can take a piece of your old hose and mate it into the end of the new hose and side it together, i had this setup on my old hatch but on my new one its just been clamped really tiite. either way works with no leaks so yoru choice or upgrade.
chrisff521
04-03-2009 05:44 AM
scul8r1990
05-19-2005 01:06 PM
runitup
11-27-2003 12:16 PM
SiR831
11-16-2002 08:09 PM
