1st Gen B16 in 91 CRX DX
I am wanting to put a 1st gen JDM B16A in my girlfriend's 91 CRX with auto tranny. I have all the parts ready for the manual swap, the Helm's wiring manual and I'll be getting the motor package with HASport mounts. I had a few things that I can't find answers to.
First, I was told there was no US counterpart to the 1st gen B16A distributor. I know lots of people out there have the B16's and I was wondering what distributor they are using when and if it comes time to replace it? Is the PW3 or PW0 ecu a better choice or are they pretty much the same spec wise? I'm still unclear on a few other things but I'll leave those for later posts.
Re: 1st Gen B16 in 91 CRX DX (VTECVillain)
The distributor uses the same internal parts as a 90-91 Integra. The PR3 ECU is better if you plan to chip the ECU since there are most programs available for it.
Re: 1st Gen B16 in 91 CRX DX (97TypeR_9)
What if you have bearing failure of the distributor housing and need to replace the distributor itself? This happened on my stock VX motor long ago and I had to buy a new distributor, but I retained my old internals.
In that case you can either buy a used OBD B16 distributor from someone or if you want a brand new one you can use one from an 88-91 Civic/CRX but you have to cut off one of the legs from what I hear. I think this also applies to the 90-91 Integra distributor housings.
RanCRX
14
03-21-2011 11:48 PM
thecorey
11-18-2002 08:35 PM
