LS VTEC rods
Old Dec 5, 2001 | 02:44 PM
H22CIVIC's Avatar
New User
Default LS VTEC rods
Are the LS rods strong enough for a LS-VTEC setup. I have the ARP rod bolts. I just want to know if it is absolutely necessary to replace rods?
Old Dec 5, 2001 | 02:46 PM
smp534's Avatar
New User
Default Re: LS VTEC rods (H22CIVIC)
if u keep it under 8k, u will be ok
just don't over ev it and u will be fine
shot peen, and acid dip em...u will be fine
Old Dec 5, 2001 | 02:51 PM
H22CIVIC's Avatar
New User
Default Re: LS VTEC rods (smp534)
Let me tell you what I have for a setup! R pistons, block girdle, ARP rod bolts, ARP head studs, GSR water pump and oil pump! I think thats about it for the bottom end. SIR head with R manifold and CTR cams with ITR valvetrain!
Do you think I am safe to rev to 8000? I personally think I am!
I would like to here more info from others that have experienced a LSVTEC setup!!
Thanks!!!
Old Dec 5, 2001 | 04:00 PM
1.8DC2's Avatar
I'm using the stock rods with the ARP bolts and I plan to rev to 8k and no further..the ECU i have was chipped with a 9200 rev limiter...so I'm going buy an MSD (with adjustible rev limiter)...set it at around 8200...just in case
chrisff521
May 28, 2013 11:07 AM
imskatencrzy
Sep 30, 2006 07:12 PM
rough_draft
Oct 31, 2004 03:32 PM
Mr. Softee
Sep 11, 2003 11:53 PM
stretracr
Jul 10, 2001 06:21 AM
