ls/vtec cams?
Old Dec 21, 2001 | 05:44 AM
pregunta's Avatar
Default ls/vtec cams?
I just did a ls/vtec swap in my car. B18c1 head b18b block. I want more power already. I was considering cams. Any suggestions spoon,pyr,toda,skunk2,type r? I don't want to loose any more low end in fact I need more low end. Really I just want more power.
Old Dec 21, 2001 | 06:26 AM
rainforest's Avatar
Default Re: ls/vtec cams? (pregunta)
well allthe jdm cams are mostly road racing cam'z they are made for mid-high end power. so check out dynos of different (jdm) crower cams at there site. They can manifacture any lift/duration cam you want special order not reground.
Old Dec 21, 2001 | 06:40 AM
WAFFLES's Avatar
Default Re: ls/vtec cams? (rainforest)
R cams are the best for the money. They produce good mid and tq.
Old Dec 21, 2001 | 06:44 AM
rainforest's Avatar
Default Re: ls/vtec cams? (WAFFLES)
i second that. even though there more mid-high end cams.
Old Dec 21, 2001 | 06:47 AM
pregunta's Avatar
CTR or ITR or are they the same? And will I have to change my retainers and sprins if I put in these cams?
[Modified by pregunta, 3:58 PM 12/21/2001]
Old Dec 21, 2001 | 07:11 AM
WAFFLES's Avatar
CTRintake/ITRexhaust...and it is always beneficial to upgrade the springs and retainers
Old Dec 21, 2001 | 07:15 AM
rainforest's Avatar
i would not really worry about retainers but scine you are doing the internals any ways its good to do. but defeinatly get itr inner valve sprigs at least
Old Dec 21, 2001 | 07:35 AM
pregunta's Avatar
Does the head have to be removed to replace the valve springs and retainers?
[Modified by pregunta, 4:35 PM 12/21/2001]
[Modified by pregunta, 4:36 PM 12/21/2001]
Old Dec 21, 2001 | 09:22 AM
MrFatBooty's Avatar
https://honda-tech.com/zerothread?id=43599
Old Dec 21, 2001 | 09:54 AM
pregunta's Avatar
Default Re: ls/vtec cams? (MrFatBooty)
Mr. Fatbooty you are my hero. (I'll search better from now on)
Old Dec 21, 2001 | 04:50 PM
1.8EG-T's Avatar
What pistons do you have in the block? If you have the stock ls pistons you need to change those out, or you will get valve to piston contact with ITR cams and up.
Old Dec 22, 2001 | 07:04 AM
chi1874436's Avatar
Nope. The head will only have to be removed if the spring slips down into the head during installation and hard to come out. If you will be running those cams, then you will need to upgrade to itr pistons for better clearance. I also recommend getting the retainers to retain the pressure of the springs.
Old Dec 22, 2001 | 10:15 PM
pregunta's Avatar
Default Re: ls/vtec cams? (chi1874436)
Will there be enough clearance between gsr pistons and itr rods
Old Dec 23, 2001 | 07:54 AM
1.8EG-T's Avatar
There will be enough valve clearance, but I recommend you go with itr's or b16 pr-3 for higher compression.
Old Dec 24, 2001 | 07:19 PM
pregunta's Avatar
Default Re: ls/vtec cams? (hybridrex)
Thanks now that is is done I would have put in the itr's but it is already done and I am not taking apart the head again.
[Modified by pregunta, 4:25 AM 12/25/2001]
LaOstha
Aug 3, 2006 09:16 PM
VtecDA9
105
Jan 27, 2006 05:35 AM
kriptik
Mar 21, 2005 05:36 PM
fucT
Jun 8, 2004 09:36 PM
riceball777
Dec 6, 2003 10:48 PM
