92 Civic HB Si ready to swap!
New User
My 92 Civic HB Si ready to swap! I want to do a Sir1 swap since it is more affordable. But since Sir1 use cable for tranny and my 92 EG5 use hydrualic. May I know what should I be aware of? Thanks
Re: 92 Civic HB Si ready to swap! (hkboy100)
just buy a hydro gs-r or b16 tranny. you'll need mounts, distributer from a 94-95 DOHC vtec, injectors from a 92-95 integ, and you'll need a P30, P72 or a dohc spec p28 ecu.
you can actually use your ex injectors, you can also use your current driver side mount and you should be able to use the rest of that mounts from the 1st gen, i could be wrong that the rear mount wont work though.
crxswap
12-28-2009 12:12 PM
sosleepy
07-23-2005 02:47 PM
boss0025
07-31-2004 10:30 AM
