rough running b20?
Old Dec 23, 2001 | 12:19 PM
11secdx's Avatar
Default rough running b20?
my cousin has a b20 swap in a 5g hatch. the car pulled great. but it felt like it was starving for fuel. we put a 255 lph bbk fuel pump on it. now problem is , at 45 psi , its boggs, and at 42 psi, it hesitates on the low rpms and in normal highway riding (like at 65), but WOT it runs great.please give me any help. thanks tom
Old Dec 23, 2001 | 05:01 PM
FAST94GSR's Avatar
New User
Default Re: rough running b20? (11secdx)
what all does it have internally ? That's weird, it also seems as if its running too rich. do you have af gauge? have you read the plugs?
Old Dec 23, 2001 | 11:48 PM
rainforest's Avatar
man you need some sort of fuel management you need to lean it down low and richen it up top.
Old Dec 24, 2001 | 11:44 AM
11secdx's Avatar
Default Re: rough running b20? (rainforest)
stock b20z. aem, jdm b16 header,and thats about it.WOT it runs good, but crusing at 60 , it feels like the car surges.
Old Dec 24, 2001 | 12:23 PM
Quick 200k Mile Motor's Avatar
check..
map sensor
injectors
ignition components (including coil)
camshaft timing (belt?)
a fuel pressure of 42psi seem kinda high for a stock b20z.
Old Dec 24, 2001 | 12:38 PM
Kaotik Individual's Avatar
New User
Default Re: rough running b20? (Quick 200k Mile Motor)
my B20 feels like that sometimes
surges at partial throttle
but i guess that is cause the DX ECU has different Fuel/Ignition maps than what the B20 is really supposed to have
at WOT the car is amazing
and I have my fuel pressure set at about the same you do.
I'm currently looking for someone that can Chip my ECU for an all motor B20 program if their is one.
Old Dec 24, 2001 | 02:14 PM
spankaveli's Avatar
what ecu r u running?
Old Dec 24, 2001 | 07:52 PM
Trickturn's Avatar
Default Re: rough running b20? (Kaotik Individual)
I know
Raver Motorsports might be able to hook you up. They are in Visalia, CA. (559) 733-4711
Pete
Old Dec 25, 2001 | 07:10 PM
#417R's Avatar
I would suppose your cousin is running a ls computer. Was he having this problem before he installed the new pump. Kind of sounds like some type of air leak. But that's just a guess.
Old Dec 26, 2001 | 07:26 AM
bgod's Avatar
Default Re: rough running b20? (b20zkid)
my friend had the same problem with his 92 eg hybrid. we put a 255lph fuel pump in there and it was way too much. the car bogged and stuttered.
basically, yoiu need an aftermarket fuel regulator or you need to put back the stock fuel pump.
this will solve your problems.
Old Dec 26, 2001 | 08:20 AM
Suprdave's Avatar
Default Re: rough running b20? (bgod)
Seriously, with a B20\VTEC...you should be using 310cc Injectors and a V-AFC.
You obviously need something to lean it out down low.
Suprdave
turbodcxbro
Engine Management and Tuning
Apr 10, 2011 04:52 PM
92slamed4door
11
Feb 28, 2011 09:24 PM
rexracer626
Jun 24, 2010 06:28 AM
JCushing
Jun 20, 2009 11:37 PM
teg92
May 11, 2003 01:23 PM
