Do i need to change the axels on a 5th gen EG if i put a b18c1?
Do i need to change the axels on a 5th gen EG if i put a b18c1? 3rd gen gsr motor in a 5th gen Eg. Do i need to change the axel(s) in order to put the gsr motor?
Re: Do i need to change the axels on a 5th gen EG if i put a b18c1? (Lookincrazy)
yes...you need to use the gsr's axels, the shift linkage as well and the motor mounts. http://civicb18c1.freewebspace.com/
Re: Do i need to change the axels on a 5th gen EG if i put a b18c1? (milo)
You can keep the driver side mount, rear bushing, and depending on the tranny- you can keep that side also. You will have to get a GSR rear bracket, axles, and shift linkage.
Lookincrazy
12-23-2001 07:37 AM
