H22 hesitates on initial throttle
Old Jul 27, 2002 | 09:38 AM
vtec2nr's Avatar
Default H22 hesitates on initial throttle
97 H22 motor with a 96 ECU in a civic coupe. It's at stock fuel pressure, and runs a little rich, but not bad. I/H/E, otherwise stock. The car goes pretty good, but we can't figure out why it bogs a little when you tap or first press on the gas pedal? Any suggestions?
Old Jul 27, 2002 | 02:54 PM
BoM's Avatar
BoM
Default Re: H22 hesitates on initial throttle (vtec2nr)
vaccuum leaks?
my friend is having the same problem also...
bumpppp
Old Jul 28, 2002 | 07:52 AM
Finest's Avatar
Might want to check your timing.
H22*CiViC
Jun 8, 2010 12:54 PM
rexadict
Feb 3, 2006 05:55 PM
