B16a into EF Q'
Old Jul 30, 2002 | 05:51 AM
No-Gi's Avatar
Default B16a into EF Q'
I will be swaping a 92 b16a into an 89 CRX. What distributor do i need and what allternator do I need?
Thanks
Old Jul 30, 2002 | 12:14 PM
91SiKen's Avatar
Default Re: B16a into EF Q' (B16aEK)
Depends, I think I have a 92 from a JDM 'Teg, and it is OBD 0. Let us know what color your plugs are. I can't remember if they are supposed to be white or gray for OBD0, but I will go check.
Old Jul 30, 2002 | 05:59 PM
No-Gi's Avatar
Default Re: B16a into EF Q' (91SiKen)
The motor is OBD-1. The plugs are gray. i have done swaps in EG and EKs but never in an EF. Let me know.
Old Jul 30, 2002 | 06:51 PM
StorminMatt's Avatar
I would just use the distributer that comes with the motor. If you try to go with earlier electronics, you will end up having a hard time finding them and paying a bundle for them. The conversion harness is no more expensive. And if you can do the conversion yourself (and it is really not that hard), the cost of the conversion is nominal.
Blue Hybrid
53
May 1, 2018 09:42 PM
Vtec-CRX
May 2, 2010 05:40 PM
91 ef hatchback
Apr 11, 2007 08:24 PM
raymas8
Jul 27, 2004 05:56 PM
