97 USDM ITR in a 97 DX Hatch troubleshooting
helping a friend put a 97 USDM ITR in a 97 DX Hatch. everything installed and wired up. engine starts fine, but idles like crap. only code from the 97 ITR ecu is for the secondary O2 sensor (using a test pipe). engine sounds like its misfiring, runs very rich, and will not rev past 3k rpm. all sensors in correct places and no vacuum leaks. the previous motor in there was a 99 LS motor. the civic harness from the LS motor was put on the ITR motor. would this have anything to do with why its not running correct? thanks in advance!
Re: 97 USDM ITR in a 97 DX Hatch troubleshooting (97hb)
they aren't switched. engine runs the same when they are switched. also the IACV and IAT are not switched.
Re: 97 USDM ITR in a 97 DX Hatch troubleshooting (*******)
[Modified by 97hb, 5:56 AM 7/22/2002]
