88-91 CRX is it hard to swap in a SOHC 92-95 SI motor in to it?
Well I am looking into getting a daily driver and have found a crx for 950 and well I have not scene it I know the motor has to be shot or the interior has cat **** all over it anyways. Instead of putting a B series motor in it and what not becasue of price I was wondering how hard it is to swap in a SHOC SI motor in a CRX what extra parts do I need and will the stock SI ECU plug and play?
Re: 88-91 CRX is it hard to swap in a SOHC 92-95 SI motor in to it? (underrated99si)
nobody knows if this swap just works or not common somebody has to know
check out http://hybrid2.honda-perf.org/tech/4gtech.html#sohcvtec
hope this helps
and this http://hybrid2.honda-perf.org/tech/s...c.html#updates
[Modified by Civicboy, 3:00 PM 7/31/2002]
hope this helps
you should find out which model crx. if its the dx then there are some wiring issues. otherwise its a very easy swap. if its an si you're golden.
