a little wiring help for a 1st gen b16 in a DA teg.
I know that I need to add 4 wires, and I know where the wires are taped into the ecu, but i dont know where the wires connect to the engine. I know the vtec sylanoid (sp) wire goes to the green harness under the sylanoid, but the other 3 wires (vtec pressure, knock sensor, and 2nd o2 wire) I dont knwo what harness to hook them up on the engine. any help???
Re: a little wiring help for a 1st gen b16 in a DA teg. (311)
the vtec oil pressure is right under the solenoid, should be green.. the knock is on the back under the intake manifold... and the o2 should be on the exaust manifold
Re: a little wiring help for a 1st gen b16 in a DA teg. (r7)
but: the knock sensor "is on the back <u>of the block</u> under the intake manifold"
small point - i know, (but for sake of correctness and stuff...)
t..
juicy.koreans.suck
12-26-2001 09:34 AM
