injectors/resistors/distributor?h22 swap,help!
obd2 h22 going into a 98 civic dx,obd1 conversion,both engine and car Canadian
1)Will I need an Accord distributor?What model and year of Accord should I look for?
2)Will I need some larger injectors when I convert to obd1?
3)Whats this about needing resistors for the injectors?Will I need them?
New User
Re: injectors/resistors/distributor?h22 swap,help! (mr.wong)
1: No, you can use the dist on the h22, you will have to re-pin the wires, but thats nto a big deal, just match it up, color to color.
2: no. use the injectors that come with the motor, if its an obd 1 motor (and I think obd2 as well) you will need an injector resistor box, you can get one from an accord or prelude (5th gen prelude, 94-97 accord) pretty easy, the yellow/blk wires go the the box, the other color wires go to the ecu (there are two wires per injector, a common, yellow/blk, and the other color (red,brn,blu,yellow? I think)
good luck
3: you will only
Soda Popinski
02-03-2004 04:23 PM
