obd1&obd2 ??? with b16a2
Old Jul 25, 2002 | 02:52 PM
ef civic's Avatar
Default obd1&obd2 ??? with b16a2
if i'm swapping in a b16a2 into a 92 hatch do i have to change any of the wiring or do i just use a 0bd1 ecu and add the other wires for the vtec and knock sensor,ect
Old Jul 26, 2002 | 12:16 PM
g's integ's Avatar
Default Re: obd1&obd2 ??? with b16a2 (ef civic)
Get an odb2 wiring harness.
Old Jul 28, 2002 | 02:42 PM
ef civic's Avatar
Default Re: obd1&obd2 ??? with b16a2 (g'sinteg)
Old Jul 28, 2002 | 02:50 PM
JV's Avatar
JV
Who?
You will not have to run the VTEC wiring. All 92 Civics came pre wired for VTEC. You may have to add the knock wire (depends on the ECU your planning to use). It should all be plug and play with an OBDI ECU...
Old Jul 28, 2002 | 02:58 PM
ef civic's Avatar
Default Re: obd1&obd2 ??? with b16a2 (JV)
thanks for the info jv so i don't have to change anything on the obd2 motor like injectors or distrib to obd1 it's just plug and play with a obd1 ecu [exept for some wires] because kenji recommended just grabing a obd2 gs-r engine harness and using that with a obd2 ecu but i'll like to keep my car obd1....
Old Jul 28, 2002 | 03:12 PM
JV's Avatar
JV
Who?
Is this motor from a 99-00 Si?
Old Jul 28, 2002 | 04:14 PM
ef civic's Avatar
yes it is
Old Jul 28, 2002 | 04:39 PM
JV's Avatar
JV
Who?
OK. That explains why he would say that. It would be wise to listen to kenji on this one...
EF_Tovi
Oct 22, 2013 06:30 AM
dwarfsinhondas
Engine Management and Tuning
Apr 14, 2008 04:50 PM
zamboolicious
Feb 6, 2008 05:44 PM
Slimm-rw-
Jun 13, 2004 08:24 PM
kvh
Jan 28, 2003 02:54 PM
